Spacer Question
01-20-11, 09:55 AM
Spacer Question
If I were to put a 25 mm spacer on the rear...I understand that i have to swap the studs for longer ones..but if I were to take the spacer off would I have to have the studs switched back? or can I put the spacer back on and off when I want?
01-20-11, 10:04 AM
I'd suggest the bolt on spacers to save you the trouble from swapping studs back and forth. Ichiba V2 or Project Kics.
01-20-11, 10:12 AM
FYI, changing studs are not easy. Longer studs are prone to bending stress leading to failure.
IMO, stay away from spacers. There is a thread about damaged spacers.
01-20-11, 11:23 AM
I would go with the V2 spacers so you don't have to worry about it.
01-20-11, 11:44 AM
Thanks for the reply everyone. Still searching what to do cause Im putting a spacer on my rear for sure...Any other options?
01-20-11, 03:10 PM
I have ichiba version 2 spacers and they are great. I would definitely recommend getting those for sure. :-)
01-20-11, 05:28 PM
Tech Info Resource
Quote:
Originally Posted by
jbjones85
Those are the least reliable kind of spacers - most prone to catastrophic failure.
cupid0210
You might want to see this thread before telling someone how great those spacers are.
01-21-11, 02:19 PM
Do project kics have hubcentric rings? or any brand for that matter?
stevenjai
03-29-12 07:21 PM
7MGTEPOWA
04-16-11 01:44 PM
Rich27
Wheels, Tires & Brakes Forum
03-31-09 11:00 AM
SloGS400
11-11-07 11:27 AM
