RPM's while stopped
I have a 2011 IS350 and have noticed that while sitting at a red light the RPM's will sometimes jump from around 600 - 700 to over a 1000. It even causes me to have to push on the break a little harder to hold it and then when I let off the break it jumps forward. It seems to be worse when the engine is cold. Do these cars sometimes run a higher RPM when cold to get the engine warm?
lol @ this thread. When the car is < op temp, it will idle higher because the ISC (idle speed controller) causes it to idle a little higher. This is basically how a choke worked on cars with carbs. It does that so fuel doesn't atomize and condense on the cold metal. Because if it did, it would lean out the Air Fuel.
hmmm... yeah, it's normal for the engine to idle higher when it's warming up. But I don't think I've ever seen it "jump" when at a stop light, nor have I had to hold on to the brakes any harder. Maybe I just have a heavy brake foot with a weak 250 motor?
Does this only happen when the engine is first starting up?
I almost hit a person crossing the street because the rpm's suddenly jumped from like 700-1500. When it's cold my rpm's jump around randomly untill the engine is at operating temp.
