Need help identifying oil leak...
Old 01-22-11, 11:39 AM
carlos
carlos's Avatar
Default Need help identifying oil leak...
Hey guys. Below is a picture of an oil leak my 2006 IS350 has developed. It is on the passenger side of the engine. When I park the car in the garage over night and move the car the next morning, there is usually a drop on the floor. I have circled where I believe it is coming from. It is some sort of bolt. It is not loose as I tried to tighten it and it wouldn't budge. If any one has any insight on what is wrong, please post up. Thank you.
This is looking under the engine on the passenger side:
Old 01-22-11, 11:59 AM
carlos
carlos's Avatar
After a little bit of searching, I may be part of a TSIB from February 16, 2007.
TSIB EG001-07 - GR-FSE SERIES ENGINE OIL LEAK
Is the area pictured above the near timing cover or the camshaft housing sub–assembly?
Old 01-24-11, 06:09 AM
carlos
carlos's Avatar
Anyone?
Old 01-24-11, 08:13 AM
VPIS350
VPIS350's Avatar
I'm not sure if its the same but my 06 had a leak last year with around 50k. They found it when I went in to the dealer for a service. They fixed it all for free.
Old 01-24-11, 08:15 AM
carlos
carlos's Avatar
Can you possibly pull out the paper work for that visit and see what it says?
Old 01-24-11, 08:23 AM
Micaiah
Micaiah's Avatar
If you tried to tighten it and it's not moving, it's possible the leak is coming from elsewhere and the oil is settling in the area you pictured.
Old 01-24-11, 09:43 AM
VPIS350
VPIS350's Avatar
I'm stuck right now in the hospital. :/ but when I get the chance ill take look.
Old 01-24-11, 10:22 AM
Micaiah
Micaiah's Avatar
Ooo. Hope everything is okay.
Old 01-24-11, 10:45 AM
carlos
carlos's Avatar
That or perhaps that bolt has a gasket and its messed up or something.
Hopefully this is part of that TSIB I posted about in the 2nd post. It would just be nice if someone knowledgeable about it would chime in and offer some insight.
Old 01-24-11, 10:48 AM
Micaiah
Micaiah's Avatar
Okay I'll shut up. Just trying to help. *goes away*
Old 01-24-11, 10:51 AM
carlos
carlos's Avatar
LOL, I meant knowledgeable about the Oil Leak TSIB.
Old 01-24-11, 02:58 PM
Sffd103
Fire Slayer
Sffd103's Avatar
I took my car in for an oil change and they noticed a leak...it had a TSIB...repaired for FREE!!!!
AZ06IS350
03-28-23 05:01 AM
rktinc
04-15-19 09:13 AM
chattanett
08-14-18 08:17 PM
Hiroshi12
26
12-23-16 02:59 PM
John5000
10-06-10 11:54 AM
Quick Reply: Need help identifying oil leak...
