Show your interior thread.
#333
Matte Wood Trim
Never was a fan of glossy wood trim. So I covered it with this. It kinda looks the matte wood trim that you'd see on most high end modern vehicles and latest Lexus models.
#336
Thanks.
Thank you. The material is called Tamo Wood Di-Noc by 3M http://www.metrorestyling.com/3M-DI-...ocdarktamo.htm. You can also find them on EBAY or Amazon. The material is unique in that you can feel the grain giving the sense that it's real wood not some printed pattern. Good quality too, won't easily tear and easy to clean.
#337
Thanks.
What do y'all think would look best with the light tan interior? Need some opinions.
#338
I think the dark wood would make a nice contrast/match with a tan interior. IMO, I would much rather have my interior in tan to go with this vinyl wrap I have on my car. This might give u an idea:
#339
And the dash and door panels will be replaced with the recall in May...
#343
#344
#345
I appreciate it. Here's a DIY: https://www.clublexus.com/forums/is-...m-removal.html. The tricky parts are the corners, the shifter gate, and the cup holder cover. The cup holder cover has 3 clips located on the back end(facing the arm rest) and 2 hook-like clips on the front end (facing the dash). The trick is to pop the 3 clips on the back end first then it will come loose. Just be cautious as to not break the clips. I broke one but it still holds shut after the fact. GL!
