fault whilst stationary
I have a 2010 ISC350 and 3 weeks ago i was stationary at lights and my car carried on moving even with my foot on the brake,i then put it in park and it still didnt stop and i hit the car infront.Has anyone else come across this, lexus say they cant find a fault, im scared to drive this car now.
Merkur Fanatic
Over a certain speed, putting the car in park will not stop or slow it down.
So, you were stopped at a light and all of the sudden the car started moving, even though your foot was still on the brake?
Sounds very strange...
If your car was stationary and foot on the brake, why would it still accelerate? Unless you meant to stop the car and it was slowing down, and You shifted to park to force it to stop before you hit the car in front of you. Shifting the car to park will not stop a 3000+ lbs car while it's already in motion.
Did you check if the accelerator/gas pedal was caught by the mat? But you would hear the engine rev up...
As noted the car will ignore P above a couple mph to avoid destroying the transmission (it'll ignore R at speed too for the same reason).
The brakes are a lot stronger than the engine though, so it's impossible for the car to randomly start moving forward unless:
A) something was wrong with the brakes
or
B) You were stopped on some surface where the brakes could not stop the car (ie a sheet of ice or something where the tires had nothing to work against)
or
http://www.youtube.com/watch?v=XjWX4...D8147A1B1D5DD6
Wow thats crazy, someone had some cahones to try that.
Like this video shows (I WOULD NEVER ATTEMPT THIS THOUGH!!)
