XM Satellite Receiver no longer available.
Keeping it Real
The funny thing is, I bet the XM Tuner/wiring in the newer cars that have factory XM will probably be available for years and years to come. The parts these guys are looking for are accessories, and are doomed to an early grave. If you could figure out if the newer factory parts would work in the older cars (they very well might), then that might be an option, however generally speaking factory parts are a few times more expensive than accessories (priced to be added to the car, versus priced for replacement and long-term availability).
Jeff
Given that XM was a factory option you could order with the car (it was in the car before the dealer touched it) I'm not sure how they're making the distinction of factory vs. accessory in your post...can you clarify? and are the newer ISes that come with XM standard getting it via some totally different hardware than the 06-09 cars did?
Keeping it Real
1. Factory parts, these are the parts that are used AT the factory.
2. JPIO parts (Japan port installed options), these are parts installed after the car leaves the factory, but before it leaves Japan.
3. PIO parts (Port installed options), these are parts installed after the car gets to it's destination country but before it gets to the dealer (can be national or regional parts).
4. Dealer-installed accessories, these are parts installed at the dealer before or after the customer takes delivery.
5. Performance parts (TRD/F-Sport)
Within each category there are some further breakdowns, like for TRD, you've got regional TRD parts, like TRD USA "sport parts" which are usually just already available aftermarket kits, etc. that TRD rebrands, then you've got Toyota Technocraft (TRD Japan) parts, which are usually quite superior, and often built exclusively for TRD.
There are also some overlaps sometimes, like when Lexus offers a part both as PIO or as dealer installed, or you order a JPIO part to add after the fact, etc. People also frequently order factory parts from other grades/models/option packages and install them.
For example, the accessory spoiler for the 2IS is available at a cheap price, usually under $200. The factory spoiler used on the IS-F and F-Sport is around $500. What happens once the 2IS goes out of production? That accessory spoiler is going to go obsolete within a few years. The factory spoiler? You'll probably be able to buy that part for many more years to come.
Same goes for the "F-Sport" accessory wheels, those will probably be discontinued in a few years time, the "F-Sport Package" factory wheels on the other hand will be available for a long time.
Try to order some accessories for the Supra. Other than the floor mats (which were discontinued years ago, but were just reintroduced for the JZA80), you won't be able to get anything. It was all killed around 99-01. Factory parts? No worries for the most part. Most are still available unless they were rarely used.
Enough about that though, getting back on topic here, the 06-09 IS never came with factory XM. If you ordered it with XM and it wasn't dealer installed, it was port installed. 2010+ IS models have the XM receiver built into the head unit in the dash, there is no separate satellite receiver.
Jeff
Ah, the PIO distinction is where the disconnect was... my XM receiver was in the car when the dealer received it, they didn't touch my car at all besides physically moving the thing off the truck. (I took possession with the paper still on the exterior and the plastic still on the seats, etc).
I hadn't realized Toyota discontinued even PIO parts long before the factory-factory parts... thanks for the info!
Keeping it Real
The nicest accessories, and Toyota/Lexus does do this sometimes, are the ones where they have an accessory which is a factory part. So you get it for the price of an accessory, but if you need to replace it later, it's the same part as was used from the factory. Not that common anymore, but it used to be more commonplace. Older A/C kits are a good example, they always just contained the same parts that were installed at the factory (though they usually had shorter lines with more connections, but in the EPC they would list both choices).
Jeff
Jeff
man this is signs that my car is getting out of date, i have a 07 with NO XM, i had always wanted to buy the unit its like $800 from lexus and install myself, i recall someone here had a nice DIY on how to do it. I do have my XM account with my acura TL 07, i always wanted to swap it over to my IS...oh well.
dang i got lucky with mine. the previous owner already had the factory one installed. i just bought a year subcription to sirusxm for a birthday gift to myself for 77 bucks. they wanted 199 but i told them i saw a deal online for 77. she said hold on while she talked to her manager, then she came back and said ok.
I have the box and mounting bracket from my old car sitting in my garage I have been meaning to put up on ebay.
*****Box, bracket and harness are sold******* I have been getting PM's on it and I feel bad getting everyones hopes up.
jamessinh
01-19-12 02:57 PM
Chuck W.
02-23-08 02:14 PM
