Fender Modding ? with +22 Wheels
I have your exact setup for my volks, except for a 255/35 in the rear. You WILL need to do fender mods. I rolled all four corners, still rubbed a tad in the rear, so I shaved a little in the rear. Only on fast corners do I rub on the bumper tab on the front passenger side.
Sorry for not making it clear in the above photo, but that's me turning into my driveway, also how I check for rubbing. My passenger rear in this pic was a few mm off the ground. Here is a pic of my car leveled
at the s-tech ride height, definitely roll your fenders.
shaving your fenders also works, but note that once your fenders are shaved, you can't roll them. on the other hand, rolling your fender still leaves the option to shave your fenders in the future if you need maximum clearance.
rolling your fenders also pulls the fenders out a little bit. yes, the paint on the 2is is not very strong and will crack easily, BUT if it is done carefully and by a competent, experienced fender roller, you should not have that issue. case in point, my fenders were rolled by a highly-experienced fender roller and i have not had issues w/ my fenders post-rolling.
aside from the fender are the fender/bumper tabs. given your ride height, you may not need to shave/modify them. any lower, however, and it'll be a must - especially up front, since the front wheels turn in/out in addition to suspension travel vs. the rear wheels that just have suspension travel to deal with.
Ling2IS
12-21-16 08:09 PM
