Changing flappy paddle timing, is it possible?
I use sport mode all the time also, even when not using the flappy paddles or gear selector. I like the fact that for driving around town in sport mode 4th gear is selected (unless you select a higher gear of-course) and the car isn't in 5/6th gear doing 30mph. In sporty mode I like to use the paddle shift to keep a gear and for downshifting. Lifting slightly (the throttle) between shifts and getting back on it gives a cool exhaust note. I would also like to quicken up the shift response gear change as well. A friend says computer shift points and speed (by increasing the hydraulic shift pressure) can be done on other cars with a automotive diag program and re-flashing the ECU. Anyone know about an application for the Lexus? And before you ISF and Manual guys chime in, I already have a Porsche track car and don't want a clutch! for this everyday driver!
Since they don't even do what you want them to in the first place, asking how to make them do the thing they don't at all do faster makes no sense.
If you want faster shifts in a performance sense leave it in D.
The only thing you're doing in S mode is slowing the transmission down by adding a delay before the FULLY AUTOMATIC transmission is allowed to use the additional gear (or notice a locked out gear, depending which way you go) that you selected with the paddle.
(FYI- the F doesn't have a clutch pedal, but does allow direct shifting of gears...and it shifts a ton faster than anything that does have a clutch pedal)
Otherwise I'd suggest you reverse course on doing that... brakes are a lot cheaper to replace than powertrain components.
The 350 uses the A760E, which is also used in the Lexus GS350 and the newer 4.6L Toyota Tundra/Sequoia
The 250 AWD uses the A760H which is also used in the Lexus GS350 AWD
The 250 RWD uses the A960E which was used in the 06 GS300
levelten doesn't appear to offer anything for any of these...
These guys offer a built A760E for a mere $4775-
http://www.importperformancetrans.com/a750e.shtml
Once again, an F seems to make a ton more sense.
EDIT- a bit more searching on same site finds this:
http://www.importperformancetrans.co...here-1964.html
So for just $738 and the removed valve body from your car they'll send you back a modified valve body to act as a shift kit.
Maybe someone else out of warranty wants to be a guinea pig for this?
(it won't do jack for the paddles mind you, since they're still not shifters)
Would love to see someone here try the re-valving and let us know.
Side note: Also saw an article in the Feb. issue of Options magazine where they are doing a 6sp MT install to a 350. Was going to scan it and see if we have any Japanese reading members here to offer translation...
Vince
My understanding of the levelten mods is to open up the passages on the valvebody, and up the line pressures to take advantage of it. Suppose to speed up the shift times by a "measurable" amount (according to those on Mitsu forums that have had it done).
Vince
Vince
incharlest
04-23-13 04:01 PM
