68 LED /w modules DRL not working...
i try to install the 68 LED with the modules but it doesnt work for some reason... i thought the DRL fuse is blown but i put back the stock bulb and the DRL lights up...need help
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
You can try:
1. Make sure the module connectors are fully clicked/tight up with the LED bulb and OEM wire
2. Could be + and - are incorrectly connected. Try to unplug the module connector/adapter that connects to the LED bulb, rotate/flip the module connector/adapter 180 degree and plug it back into the LED bulb
NickawdIs
08-14-12 11:17 AM
