What size spacers are needed for my desired look?
I have an IS250 AWD and will be installing bc coils soon. I want to push out my wheels a bit but I'm not into the flush look, I'd actually prefer the wheels to be slightly tucked but not sunked in. I have the staggered oem is350 18' wheels on with 225/40/18 tires all around. My question is what size spacers should I run to achieve the slightly tucked look (also what brand is best)?
here is an idea of what I'm looking for
i have 15mm fronts and 20mm rear. they are flush but do not stick out. do you really wanna tuck? or just want it to be flat? mine sticks out a tiny bit more than that picture, so i guess 10mm frount and 15 rear for you?
Park your car on level ground. take a piece of string or thing thread. tie a bolt around one end. take the other end and tape it to the top center of your fender. let the bolt end hang down. take a ruller and measure from your tire to the string. that will give you a flush look. take off or add millimeters for your desired tuck or poke.
Really??? I was told otherwise and went through a lot of trouble to get my 255/35/18 rear for my Gspiders. * OP, sorry for thread jacking. GL with that look!
ah damn i just asked this question with out searching...what a noob! I think ill do 20 in the rear and nothing in the front. Im running 235s all around...i was going to go back to 225 and 255 when these are worn though....are there any gains from running the OEM tire sizes verus 225 or 235 all around?
JDKane527
03-24-09 07:23 PM
