Anyone try this iPod Integration kit?
#31
BTW if anyone is still having trouble picturing this, the cheap version is here:
http://cgi.ebay.com/Black-iPod-iPhon...#ht_3497wt_801
Dock to aux.
The pricier one is something like this:
http://www.amazon.com/Kensington-Cha.../dp/B0031U1AU0
Which both charges and provides a line-level output both using the dock connector at the same time
Both will give you the same audio quality as an integration kit (which would also just be getting the audio from the dock connector), but neither will display info on the dash or let you change tracks with the steering wheel buttons.
#33
Ive been reading the reviews on the one with the charger, got some pretty bad reviews.
Oh, absolutely... well, you can still use the volume controls on the wheel with AUX... but you can't change tracks that way... and you won't get any info displayed on the dash from the ipod with AUX either.
Dock to aux.
http://store.apple.com/us/product/TW...co=MTA4ODAyNjU
Dock to aux.
#34
Sorry, I was not recommending a specific brand, it was just the first one I found in a google search with a decent picture to show an example...
I personally use a Belkin that I've had for like 4 years now and it continues to work flawlessly (though it did need an extra power-adapter on the dock plug if you wanted it to charge the newer-gen iphone/ipod since Apple changed what charging methods they support since I originally bought it)... have used it with an ipod classic, iphone 3G, and now an iphone 4
Belkin doesn't seem to sell my specific kit anymore, but here's a Kensington one that looks similar and directly supports the current-gen phones and ipods that has good reviews for under 30 bucks
I've edited my previous post to substitute this example for the poorly reviewed one.
#35
Sorry I haven't had much time to do a video yet.
Using the simple eBay vs the aux jack is very big difference in the sound quality. Obviously with the iteration kit the sond is alot more crisp and clear, I have a sub and even the bass has better response.
Using the aux and using a charger at the same time just couldn't work gave me an annoying hiss. This was bad bc you could only listen to you playlist until the iPod died then you had to wait for it to charge. Negative
The isimple is a good price and good quality. Like I stated its plug and play displays text and you can still use steering wheel controls. If you have navigation you go I to audio and setup playlist by artist/genre ECT. Very simple to use. The isimple Is used through sat/am function and the box itself have another aux port for game systems or DVD player options.
#36
You're getting the exact same connection with an integration kit as your are a dock-to-aux connector. A line level signal from the ipod to a line level input on the head unit.
identical
If you were using the AUX jack from the headphone port on the ipod then sure there's a big quality difference, because the headphone port sucks and shouldn't be used for this purpose... the dock port should (just as you use it for the integration unit)
Once it's fixed the hiss you describe goes away entirely.
#37
Thanks for all the info kurtz, but can you explain how the Aux plug under your armrest is the same as plugging into that SAT output with the integration kit? In my head, now it might not be right, but if plugging into the SAT input in the headunit thats a more direct connection right? While using the aux is like another step, possibly creating a little more distortion? I could totally be wrong. Could you clear this up?
#38
My way:
iPod dock connector-> Kensington dock-to-aux cable sends a line-level stereo output from the ipod to the cable.
The other end of that cable plugs into the AUX port, which is a direct connection to the line-level AUX input on back of the head unit over a wire.
The other way:
iPod dock connector-> ipod integration unit (VAIS, Lexus, whoever) sends a line level stereo output from the ipod to the cable
The other end of the cable goes into the integration unit, which has a direct connection to the line-level SAT (or CD for the VAIS) input on back of the head unit over a wire.
They're doing exactly the same thing- taking a line level output from the ipod and sending it over wires to a line-level input on the back of the head unit.
#39
wow
As I explained, that's flatly impossible if using a quality dock to aux connector.
identical
That's the ground loop issue I mentioned like a day or two ago is covered by a TSIB and fixed by the dealer for free.
identical
i simple is simply simple or even the vais kit mentioned plugs straight into the back of the stereo there is no this that the other the charger an annoying amounts of wires tucked inside the center compartment and you can also use steering controls. instead of fumbling around for your ipod to change the song.
either product isimple or vais is the way to go.
my camera battery is charging now for an isimple video
obviously you can run this SINGLE wire and hide it in the glove box or anywhere else.
my old setup before spending every worth penny on the isimple
#41
congrats on solving this issue of ground loop noise. and your OPINION on wether or not the sound quality is different using a headphone jack doc to aux connector and this and that and this and that peice will go here oh yeah, connector from the center console to the ipod
It's not an opinion.... if you have any valid scientific explanation for how making exactly the same type of connection with both methods would sound different though I'd be happy to hear it.
Of course there is... in fact there's MORE extra hardware and wiring with your method... it's simply more hidden once you've taken apart your console and dash to install all of it... versus my method which has less overall hardware, but remains visible inside the console. On the bright side I can also just unplug mine and take it with me to other vehicles, while you can't without taking apart the console and dash again, then doing so in the other vehicle.
Now see, that would be an OPINION
Because I'm basically making the same connection you are, just with a much less expensive device that doesn't allow head unit display/track control.
Ah, see? You were using the inferior headphone jack connection.... that explains why you heard an audio quality difference. That connection sucks and shouldn't be used.
If you had used a dock audio connector you'd have one less wire running to the phone (you'd have the same "one simple wire" running to it you have now) and you'd have the much better audio quality you enjoy now.
Anyway, really, both methods, mine and yours, produce excellent, identical, audio... yours costs more and involves a lot more install work, and can't easily be moved between cars... but it lets you change tracks and display data on the dash instead of the iphone. So it's up to each person if that's worth the cost and install and less portability. It's not for me (especially the lack of portability since I like using the ipod integration in my wifes car as well as rentals when I travel too), but obviously is for you.
#42
im sorry but you are wrong......
first off you are not producing the same method you are using the aux port headphone jack with a connecor to the ipod.
you stated yourself the headphone jack doesnt have as good quality sound from the ipod so why would the aux port?
the isimple has an amplified signal , including resistors to keep out any unwanted ground loop noise interferance.
i need not go into detail concerning the amount of freedom of wiring nor the options that your method seems to lack. considering it was already covered.
i you want a quality sound go with vais or isimple its worth every penny. "and not just for the lack of wires and additional noise"
#44
WTF are you talking about? The aux jack is line level EXACTLY like the sat Port you are using
The reason your old method sucked was you used the iPod headphone jack not the dock connector
And I surely don't want a dinky amp in the way on a cheap integration kit...that's exactly the problem with using the headphone jack on the ipod, you're getting a signal through a cheap amp... I want a clean line level signal for my nice mark levinson amp to use
The ground loop isolator is in the aux jack too with the tsib as I said
So again my method gives AT LEAST as good and clean a signal as an integration kit and better if the integration kit puts some cheap amp in the way
The other advantage of my method over the cheaper integration kits is you don't lose the factory XM radio if you have that option (which I do)... to do integration in that case you need to spend the extra $ for something like the VAIS kit that doesn't use the SAT port on the head unit.
#45
Kurz is right on this one... It's the HEADPHONE jack o the iPhone that puts out a crappy signal. (crappy amp on iPhone). By using the dock connector, you get a much better signal - better quality of music.
Personally, I would still use an iPod integration kit so I can use the steering wheel controls (changing songs without taking my eyes off the road), but that's for the Op to decide.
