Fog light modification with Toyota OEM fog switch
Here is the additional info on the Toyota fog switch and retrofit that I have done. I took some photos while doing the trial and error approach. For those who might be interested in DIYing, I will let the pics tell you some key info in order to make the mod work. However, do it at your own risk/your own way and I will not hold any responsibility if you damaged your car and/or yourself. Good luck ![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
1. Fog light switch:
![Fog light modification with Toyota OEM fog switch-img_4794.jpg](https://www.clublexus.com/forums/attachments/is-2nd-gen-2006-2013/200181d1461114128t-fog-light-modification-with-toyota-oem-fog-switch-img_4794.jpg)
2. Connection diagram:
![Fog light modification with Toyota OEM fog switch-img_4826.jpg](https://www.clublexus.com/forums/attachments/is-2nd-gen-2006-2013/200185d1461114131t-fog-light-modification-with-toyota-oem-fog-switch-img_4826.jpg)
3. Indicator and back-light swap (i.e. amber and green light swap):
![Fog light modification with Toyota OEM fog switch-lightswitch.jpg](https://www.clublexus.com/forums/attachments/is-2nd-gen-2006-2013/200182d1461114131t-fog-light-modification-with-toyota-oem-fog-switch-lightswitch.jpg)
4. OEM harness retrofit (or on your own more creative way
I can't get the OEM harness to work as it only lights up passenger side fog. I think it could be due to the tapped wires that I used are 16 gauge.
![Fog light modification with Toyota OEM fog switch-retrofit.jpg](https://www.clublexus.com/forums/attachments/is-2nd-gen-2006-2013/200184d1461114131t-fog-light-modification-with-toyota-oem-fog-switch-retrofit.jpg)
5. Re-use OEM harness sleeve (optional):
For a cleaner look, use the OEM harness sleeve to cover/contain the 2 tapped wires in the engine bay and knee panel; the sleeve is long enough to cover all the way from the fuse box to the interior knee panel.
![Fog light modification with Toyota OEM fog switch-img_4845.jpg](https://www.clublexus.com/forums/attachments/is-2nd-gen-2006-2013/200187d1461114131t-fog-light-modification-with-toyota-oem-fog-switch-img_4845.jpg)
I added this switch recently as well and you really don't need the harness and can use butt connectors to save yourself some money.
http://cgi.ebay.com/ebaymotors/FJ-CR...Q5fAccessories
^^^ was the cheapest switch that I found, really fast shipping btw and out of socal.
They also have the switch/harness combo for about $30 more.
![](http://www.afj4x4.com/images/fj%20swicth%20info.bmp)
Diagram on how to wire the switch without the harness.
I like the look of the OEM switches, but they are a bit pricey. I needed 3 switches for my mods (Fogs, DRLs & Nav), so I went with these that have been mentioned before. I got all 3 for the price of 1 OEM:
http://www.oznium.com/gsw-45-led
Nope, this mod does not need to tap wire to the **** / switch on the steering column. However, if you want the Toyota fog switch back-light to lit when you turn on the parking/head light, you need to tape to interior power resource. I tapped to the sunshade switch.
Great DIY, I wish I can do this on my SC. Been researching for the SC for quite a while.
Thanks for this DIY.
