Has anyone added a center channel to their non-ML system?
Old 02-21-11, 10:11 PM
AZ IS350
AZ IS350's Avatar
Default Has anyone added a center channel to their non-ML system?
If so, how did you route your speaker wire through the dash? Yeah I know the non-ML OEM amp doesn't have center channel outputs.
I have the MS-8 processor installed in my audio system and have a free output I'd like to use to add a center channel to my non-ML system. I popped the cover off and looked around as best as I could see. It appears the internal pathways run primarily horizontal along the windshield towards the A-pillars. I taped speaker wire to a fish tape and tried to find a opening to pass it through under the dash on the driver side but couldn't find a route. I didn't try the passenger side, as I was hoping to route my speaker line along the driver side, but I can go that way if there's a route.
Any help appreciated. Maybe even one of you ML guys can tell me which way your OEM wiring runs.
Old 02-21-11, 10:13 PM
Sffd103
Fire Slayer
Sffd103's Avatar
I'm interested as well, cause in my last system they drilled right into the dash.
Old 02-25-11, 09:48 PM
AZ IS350
AZ IS350's Avatar
Bumpin up, hoping for an answer...
Old 02-25-11, 10:49 PM
Sffd103
Fire Slayer
Sffd103's Avatar
I was just looking at a 4" mid to put in there. Take the grille out and drill down in there with the radio out and feed it through.
Old 02-25-11, 11:09 PM
evogt500
evogt500's Avatar
By doing so, it wont be a true center speaker would it? You would be just tapping into the right or left speaker line right?
Old 02-25-11, 11:21 PM
Sffd103
Fire Slayer
Sffd103's Avatar
I'm building a whole new system. I'm not sure about all the details cause my Alarm/stereo shop handle all the install. I just pick what I want/like!
Old 02-26-11, 01:06 PM
AZ IS350
AZ IS350's Avatar
No way in hell I'm doing that. With my luck, I'd end up drilling through some critical cables or something else unseen. I'm trying to fit a 4" mid there as well.
You have to feed it a dedicated center channel signal, from an aftermarket processor. Feeding it a L/R signal will sound like ***.
khanhfat
ES - 6th Gen (2013-2018)
09-03-15 11:34 PM
edwinlexus
05-19-15 06:15 PM
M88JCP
11-01-12 01:28 PM
jtwenger
07-25-12 10:42 PM
350nub
08-20-08 04:24 PM
Quick Reply: Has anyone added a center channel to their non-ML system?
