HID foglight help
Old 02-24-11 | 05:03 PM
Marexus's Avatar
Marexus
Default HID foglight help
Ok so I got what appeared to be a plug and play kit
I plugged one end where the old 9006 bulb went and then plugged in the other end to the new HID bulb. Turned on the lights and I get nothing.
I put the old 9006 bulb in and it lights up when I turn the lights on. What am I missing here
Old 02-24-11 | 05:07 PM
SB350's Avatar
SB350
The polarity is reversed. Plug the harness in upside-down.
Old 02-24-11 | 06:00 PM
nyis250's Avatar
nyis250
Looks like you connected the wires incorrectly. The 2 harness from the ballast should be connected to the bulbs and the connector closest to the bulb should be connected to the OEM wiring. This should work once you make the changes. If it doesnt light up. Flip the connectors to the OEM harness upside down.
Old 02-24-11 | 06:26 PM
Marexus's Avatar
Marexus
You're awesome! All installed and working, damn are these things bright!
Old 02-24-11 | 06:47 PM
rL-gT's Avatar
rL-gT
Ding ding ding.
Had the same issue on my 250 and my 300.
andrew_A_3
IS - 1st Gen (2001-2005)
04-17-15 08:13 PM
spliff
09-08-14 08:41 AM
BinaryJay
03-24-10 02:13 PM
likopiko
Lighting
11-02-04 06:38 PM
4double0
Lighting
03-19-03 12:04 PM
Quick Reply: HID foglight help
