Halogen to factory HID headlight retrofit?
I'm pretty sure this has been successfully done before by some members, but I can't seem to find any info on it. Is this something that would be plug n play, as in:
Halogen headlight housing/halogen bulbs/halogen wiring harness swapped for Factory HID headlight housing/D4S bulbs/ballasts/HID wiring harness? Or would some additional rewiring be required?
No point of doing this too me anyways. If your going to retrofit just use your non HID headlight with some other parts to try and get a better cut-off line with an plug and play HID kit. Try these guy there from NJ http://shop.lightwerkz.net/index.php
I was considering something like that, but it wouldn't have auto leveling like the OEM HID headlights do. Beam pattern is my main reason for wanting to upgrade and I know a custom job would be the ideal way to go. But I really just want the factory look with the auto leveling and 4100K color even if its just a small upgrade in terms of beam pattern over what I currently have. But thanks for that site they're actually somewhat close to me.
Just so you know the ASF(or AFS) whatever is called wont work. You'll need 4 sensors for each wheel + probably some headlight ECU(not ballasts). The lights itself will work though.
I thought that was something different than auto leveling? I was just referring to the thing that keeps the headlights level so you don't blind oncoming traffic when you hit a bump or hilly roads. I don't really care for the thing that turns the beams when you turn the steering wheel.
To be honest there not much of a diff between oem headlight hid or none hid. They still suck compare to other cars. You spend alot more money than it's worth. When you can just put a hid kit in your headlights. Auto tilt not big deal since most of use who lower our ride manually adjust the headlights.
ThinkTwice,
Your best bet is to buy an aftermarket HID kit to install in your OEM headlights. For three reasons I can think of:
1. The aftermarket HID kits are usually cheaper than the OEM HIDs.
2. The aftermarket HID kits usually fit right into your OEM headlights without mods.
3. The aftermarket HID kits don't affect your AFS or Auto-Leveling.
I know AAC (www.aacstyle.com) used to sell HID kits for the IS. The only thing you may need to do with the aftermarket HID kits is to install a ballast in the engine compartment.
ThinkTwice,
I had a loaner '11 ES350 when I had recall work done recently and I was envious over the factory HID lighting that thing had. It may not be the best to some standards, but it was miles better than my current setup.
Then your best bet is to buy OEM HID projector headlights and replace your old headlights. Might as well go with what makes you happy. I believe they are plug and play as well. Try Sewell Lexus, I believe they are vendors at my.is and ClubLexus.
http://is.sewellparts.com/accessorie...2009/2364.html
or try out the 2011 HID headlights.
http://is.sewellparts.com/accessorie...2007/2411.html
Just to let you know ...they're expensive.
I'm PM-ing you my number. I've been trying to find a company that is familiar with our IS heads that will do retro's and guarantee their work.
Thanks for your help in keeping me/this forum updated on your experience.
Please please please let me know how it goes with them. If you end up being satisfied I will use them as well. Heck I'll even use you as a referal.
http://www.lightwerkz.net/
