Best iphone car charger?
In my opinion, the best charger/player for your iphone would be the spec.dock ashtray dock...you have to have some sort of ipod/iphone integration installed to use the dock, but it looks good, well hidden, and easy access. The only bad part is it cost $150.00...
hey thanks for your response, i was wondering I have the 06 IS w/o nav so theres no usb in the center console. So will the car charger reach? Also how is the quality when you charge AND play music at the same time cause with my old car charger theres an annoying buzzing noise when both are going on at the same time o.o
I have an '07 IS and it does not have USB in the center console either, but that doesn't matter. In your center console there's an aux-in port next to an AC/cigarette lighter port. The 3.5mm aux-in end of the Kensington cord gets plugged into the aux-in port: this plays music. The USB end of the Kensington cord gets plugged into the AC adapter that comes with the Kensington cord, and that gets plugged into the cigarette lighter next to the aux-in port, and this charges the phone.
Make sense?
And the sound quality should be fine if you play music while charging as long as you have the TSIB for ground-loop done, as that eliminates the buzzing.
pngo
06-25-19 03:34 AM
