How to take out the side roof rails?
Anyone else got any answers?
they slide forward , start with the front slide it towards the front and eventually u can lift it upwards so that you dont break the weather strip itself ,once off you can just pull up and should come off till the end which slides off also
Anybody else?
from what i asked the service guy..
he said that there's clips holding them on.. and if you wanna remove them you basically have to break the clips and get new mounting clips..
i was curious to when i wanted to get my roof black to..
You can see from the pictures the whole middle section consist of that slide on rubber stuff.
1 - Front, 2 - Back
sorry i was too late to tell you .. and no you dont need to break them to get it off, but they do slide just enough so that the clips can be removed just takes a little bit of time, but i guess the real best way is to get some type of plastic to wedge in the middle area to lift it up first then when you are at the ends you can slide them and unclip them
I had it removed twice because my roof wasn't vinyled properly the first time.
my clips didn't break. I think they just carefully pulled it upwards to take it off.
If you're planning to have it vinyled by professionals, then just go to Shinzowerks.
They'll take it off for you. But if you want them to do it properly, take off your shark fin first or else they'll just cut around the sharkfin and you'll see a bit of the white roof..
That's why I had to get it done a second time. Other than that, they do an awesome job.
