No Panels Underneath the 2011 IS's...Anyone Know Why This Is?
Part numbers for full undercovers on 2IS RWD Sedan:
51442-30151 - Engine Undercover No. 2
51449-53030 - Bracket, Engine Undercover No. 2 (for A/T)
51449-53050 - Bracket, Engine Undercover No. 2 (for M/T)
90105-10361 - Bolt, Bracket (Qty: 2)
58165-53021 - Cover, Front Floor RH
58166-53021 - Cover, Front Floor LH
58398-53021 - Cover, Rear Floor RH
58399-53021 - Cover, Rear Floor LH
65487-53020 - Clip, Rear Floor Covers (Qty: 2)
90467-09087-22 - Clip, Rear Floor Covers (Qty: 9)
52383-30011 - Protector, Diff Support RH (Different than the one used on other model years, not sure if you can use both types at the same time)
52384-30011 - Protector, Diff Support LH (Different than the one used on other model years, not sure if you can use both types at the same time)
90179-06306 - Nut, Diff Support Protectors (Qty: 4)
Jeff
Jeff
Just to make sure, these are the part numbers for everything you need to buy in order to have the complete (i.e. 2009) set, right? In other words, you're not including the OEM stuff that's already on the non-2009 cars.
I plugged in the part numbers for everything, looks like the complete set will cost about $900 WITH the CL discount, $1,350+ without. (I couldn't find one of the bolts on Sewell, which I highlighted in yellow, so just assumed it costs about $1.) Maybe this is why Lexus didn't include them in every model year. $$$
If anyone is interested in the complete set, PM me. I have all the extra panels but may not install them.
Another question for you Jeff, any idea why your part numbers differ from this post from a while ago?
https://www.clublexus.com/forums/is-...ro-panels.html
Keeping it Real
https://www.clublexus.com/forums/att...-underbody.jpg
Jeff
If anyone is interested in buying these underbody panels, I have a set for sale in the Classifieds: https://www.clublexus.com/forums/is2...plete-set.html
