How to get the rear seat cushions out of 2011 IS350C??
I want to access the side speakers, wiring to ad in a powered sub-woffer. How do you get under the rear seat?
Thanks
Thanks
There's a clip on each side (2 clips on the LH cushion, 2 on the RH).
Pull up with your hands on each side of each cushion to release the front clips (do 1 at a time). Once both front clips are disengaged, there is a rear hook that holds the rear of the cushion in, you'll need to get it unhooked and then you can pull the seat bottom out.
Jeff
Jeff
