V-LED interior lights issues
03-07-11, 02:05 PM
Try switching them to the one that works to the other prong
03-07-11, 03:53 PM
Just noticed the problem is intermittent with a single bulb in. Doesn't matter which one I have it installed in.
03-07-11, 04:32 PM
i took one of the rear dome off and it still does it... i don't want to go back to stock boring yellow bulb lol.
03-07-11, 04:35 PM
I'm thinking it has to do with vleds new LEDs. I think I'm having this issue as well. I was in the car and when my right door opened it started saying key not detected then when the door closed it went away. This happened twice today.
03-07-11, 05:11 PM
maybe cause them LED has a little chip on it that interfere with our key fob?
03-07-11, 05:17 PM
03-07-11, 05:26 PM
i just went out and tried it 4 times and worked fine
03-07-11, 05:28 PM
most time mine will detect my keys but it's just not responding to my Lock and unlock when i get out of the car.
03-07-11, 05:35 PM
2008 full v-led interior and exterior swap and no problems at all
03-07-11, 05:51 PM
I have an 2007 and I had this problem about an hour ago. The passenger side door was open, while the car was running and I got the message stating the key wasn't detected. Once the door closed the error message went away.
I've had the full V-led interior setup since September and this is the first time I've had the issue. I'll check again tomorrow and see if it happens again.
03-07-11, 06:17 PM
Is time to try out our latest led board
www.nigel-jdmparts.com
The 6 LED board which fitted in the paddle lamp will.....
03-08-11, 04:42 PM
had the issue come up twice today while i was working on my car. Its getting annoying
03-08-11, 05:33 PM
V-LEDs is checking into the problem. Still can't think of why it would happen to some cars and not others.
03-08-11, 06:01 PM
i hope they find something, im thinking it has to do with the chip on their leds
03-08-11, 06:29 PM
i actually took one on the rear dome off and it's working fine right now with my key fob. I want a fix!
