Where is the TPS?
Where is the TPS?
After removing the intake manifold to replace the sparkplugs, my car started throwing some errors about a bad TPS. I think I may not have plugged something in all the way or something. Does anyone have a picture where the TPS is?
Thanks!
Thanks!
I did clean my TB. Sprayed some TB cleaner in it, wiped as much of the carbon as I could out. Could cleaning cause any sort of issues?
Is it ok to take it apart? It looked like a nicely built TB, and not sure if I need to be a master tech to service it... I guess I'll just first fiddle around with the connection. Make sure that's ok.
But I did want to mention that other than the light, everything is running perfectly fine, as far as I can tell. Acceleration, idle, is all good.
Cp2295
11-26-16 12:24 AM
