Tail light Replacement 2007 IS250
Good day all
Recently replaced the tail light housing only to find out the brake light no longer works (blinker still does). Evidently I purchased a housing sans the bulb. My issue is that I cannot find the bulb ANYWHERE! Advice?
Thanks!
Kimberly
Thanks!
Kimberly
Hi Kimberly,
Did you install IS-F outer tails? The only bulb in those (or any outer tail light assmbly for the 2IS) is the turn signal, everything else is built-in LED. If the LEDs aren't working, your harness is probably not connected properly. Try reseating them. The bulb and LED parts of the tail assembly have different connectors, so that's why your turn signals could still be working but not everything else.
Mobius1
12-22-16 12:17 PM
