little mishap that happened on my first hands on job..
please see attached picture.. i broke the screw in half when i was removing the 10mm bolt on the right... and now half of the remaining screw is stuck in there... what should I do?
yea.. i broke the bolt when I was trying to swap my hid bulbs. I was following the youtube video where they are installing the aftermarket hids.. soon after i broke the bolt i realized i didn't need to go through all those processes because i have oem hids... and i swapped it in like 10 mins after that.
Thanks for your suggestion, but... is there any other safer alternative? your approach seems pretty technical..
The bolt is stuck in the hole it was bolted into from what I understand. I don't think it went into the snorkel.
All I gotta say is, if you broke that when you were undoing it by hand, you da man!
Yea, I did break it by hand.. suprisingly it didn't take a lot of greese either..
If it was me, I would get it out, and then replace it with a new one. The snorkel assembly likely would be fine with the body clip on the left, considering that the front engine front cover goes over it. However, if you're like me, you would know that it was jacked up. I just couldn't leave it like that. Screw extractor sets sell for around $10 at a parts store. You just drill into the center of the bolt with a small drill bit, then run the extractor (which has reverse threads) into the hole that you drilled. Once it bottoms out, it begins to turn the bolt counter-clockwise. Then replace with a new bolt. You will sleep better at night knowing you don't have a broken off bolt in your engine compartment.
joshoowa
Suspension and Brakes
35
04-30-05 09:41 AM
