Cant wait for fitment thread to respond trying to order right now! help :).
Ive been good with the modding lately so its time to get back on track.
Trying to order some enkei nt03 right now.
18x8.5 +38
18x9.5 +27
For the front,
Looks like I will be fine up front on the rims(correct me if wrong please!), wondering..
1.If tire size 235/40/18 would be too meaty?
For the rear,
1.Will stock 255/40/18 tires be fine?
2.Will I need to roll the rear fender regardless of tire size?
18x8.5 +38
18x9.5 +27
For the front,
For the rear,
245 is a hit or miss, depending on which brand/line.
your best bet is to go with the next-highest offset (+40, according to the NT03+M's spec sheet).
they don't make NT03+M's in 19's.
if you don't roll your fenders, any tire size wider than 235 (18" 40-series) will cause tire/fender clearance issues.
so u think I should run 225/35/18 and 245/40/18 rear if I go +27?
I am dropped 2" and looking for something that will end up flush without having to roll fenders. (I will roll the rears if need be)
I wont have to do any mods in the front with that +38 right?
you won't be able to "get away" with 255/40-18 on 18x9.5 +27 in the rear unless you roll the fenders and shave the rear fender tabs.
either choose a higher offset and avoid fender modifications, or suck it up and get your fenders rolled/shaved and your rear fender tabs shaved so you can accomodate lower offset wheels.
if you want to play, you've got to pay.
