G35 Coupe to Is250
You say you're coming from a manual transmission G35.
You should know that the paddles in the IS350 are not shifters. They do not shift the car. The paddles in the ISF are shifters, however.
The IS350 is a fully automatic car for all intents and purposes. The only thing the paddles do is allow you to set the range of gears within which the automatic transmission will function.
If you use the paddles to set the car to "S5," the IS350 is now a fully automatic car that will choose from gears 1 through 5, depending on the conditions. Obviously, if you're cruising along the highway at partial throttle, the car - in S5 mode - will put you into 5th gear. If you then push down on the accelerator hard to go WOT, the car will automatically shift you into the appropriate gear for a WOT situation.
For practical purposes, the paddles are utterly useless. There are very, very few situations where one might find the paddles to be somewhat useful.
If you set the car to S1 using the paddles, accelerated, and then pressed the "+" paddle to put the car into S2 before you hit the rev limiter, you might be tricked into believing that you actually had some hand in shifting the car from 1st to 2nd gear, but you absolutely did not. All you did was set the range of gears from [1] to [1,2] before you hit the limiter.
Bottom line, the paddles are not shifters. If you're the type of guy who needs to have control in shifting the car, then you have two options as far as the IS line goes -
1) 6 MT IS250 (the IS350 does not have a manual transmission option)
2) ISF (not a true manual, but you gain full control in shifting the car using paddle shifters and you can keep the car in automatic mode when you want. You get the best of both worlds with this options).
If the ISF is out of your price range and the lack of manual transmission/lack of true paddle shifters is a deal breaker for you, then the only option is the 6MT IS250.
Personally, I value the power of the IS350 over the option of manual transmission with the IS250, but that's just me. Obviously, this comes down to personal preference.
Now, obviously you'll be wanting to take a test drive in all of these vehicles before you make your choice, but for your convenience, here are 0 to X MPH performance figures for both the IS250 and IS350 -
IS250 -
IS350 -
As Kurtz (another member here on CL) would say, with the IS350 you get 50% more power in lieu of a 10% reduction in gas mileage.
Whether or not the benefits of the IS350 (performance) outweigh the costs (no true manual, no paddle shifters, slightly poorer gas mileage) is up to you to decide.
IS250 -
IS350 -
IS250 -
IS350 -
IS250 -
IS350 -
Thanks for all the info really helps me make a decision! I think in going with fully automatic car this time. Last two cars I've owned was 03 M3 with SMG transmission didnt use the paddles much! Now G35 six speed manual transmission which I enjoy but this time around think I'm going automatic! So looks like I need to test drive the is350!
You're in luck then. The IS350's automatic transmission is terrific. The only thing for you to decide now is if the back seat room is sufficient for your needs. Although the IS is classified as a "sedan" it's probably somewhere in between that of a true coupe and a true sedan when it comes to rear leg room.
Im usually alone most of the time anyways so not to worried about the room in the car i guess its more having to flip the seat forward to get one of them in or out all the time.
I had a G35 coupe and went into an IS350. The IS had enough power to keep your speed demon side under control and happy. As for room in the back seat, I don't know if you will like it. The rear seats in the IS are still roomier than the G35 but not by much. Maybe you might have to look into a car with bigger seats...
Also, don't be afraid to take your kids up to the dealership and see how they like the back seats. Also, sit in the back seats for yourself and see how you like them. You can then compare and see how it will feel to someone of the same size as you.
I don't mind the backseats because I never have people back there unless they are desperate for a ride. In that case, beggers can't be choosers LOL
The IS350 is faster than the G35 coupe. Trust me on this, I own both. Both turn heads and both are great cars, however you can't compare the coupe to the sedan.
As for the IS250, its a great practical car. Some members on here are spot on in regards to looking at an ES, and I'd even recommend the GS300/350. Your little angels will continue to grow and you'll need to adjust to their lifestyle...heaps of diapers, then little league sports bags, then a tirade of birthday celebration supplies to Chuck E. Cheese, etc.
Also consider the G35/G37 SEDAN and the TL; both too are great cars, reliable, and fun to drive.
I have one son who is 8. The main thing I like about the IS is that it has the feel of a coupe, with the convenience of 4 doors. No, you will not make any friends if you try to take adults on a long trip in the back seat. But I did not want my son having to crawl out of a coupe every morning when I drop him off at school. Once he gets big enough to need the leg room, he will be riding up front with Dad, in style If there are more than 2 adults needing a ride, we take the SUV. That's what they are for!
Edit: Go for the 350. I still can't figure out why people buy the 250 in such great numbers, when for 3-4k more you get a car that looks fast and actually IS fast. :duck:
