Another TPMS ??? Need help
I have searched for days now and cant seem to find the answer to my question so here it is. i got my new MS1's about 2 weeks ago and i ordered the TPMS adaptor because i didn't want to drill these wheels or make a "pipe bomb" and my problem is the TPMS adaptor valve stem is too big and doesn't fit through the valve stem hole on the rim see photo's below for details so is there a adaptor out there that will work ? Thanks in advance guys/gals
this photo compares the adaptor and the SSR valve stem that came with the rims.
this is the adaptor
i need one this size.
this is the adaptor
TPMS part # 42607-33021 is what you want you can buy them off here pretty cheap http://www.oewheelsllc.com/TPMS-Sens...-p9327324.html
if it's becoming to much of an hassel with getting the right adapter and you don't not want to do the pipe bomb method. search for the zip tie method. essentially you put a pice of plastic between two sensors and zip tie them together. the tpms pressure sensor is on the bottom of the tpms, hence the reason why this works. search for the topic.
for me i like having my tpms installed on rims, i drive to long of a distance every day to have a tire start going down on me and not know it, would do some pretty good damage.
Salil022
03-02-15 06:45 PM
UberNoob
Wheels, Tires & Brakes Forum
12-27-09 01:00 PM
