OEM Aero Kit - Front Lip and Rear Bumper
Keeping it Real
Well, I honestly don't know if they'll fit yet, I'm sure they will. Sewell isn't wrong though, they're not a direct fit, and there aren't going to be instructions (at least not yet) on how to do it. They're just a factory replacement part, not an add-on like the GFX was.
What colour is your car? I can see if I can track down the part numbers for you. I'm sure your local dealer would also be able to look them up as well.
Jeff
Jeff
Jeff, I am pretty sure it should just fit, cause i don't see the point of lexus makes 2 different bumper for 2011? thats just too much trouble, Ive put my F sport lip next to the bumper, and it looks spot on.
there are TABs that come on the F sport front lip, there is a member on here said that there are marks behind the bumper tells you where to cut the hole for the Fsport lip on a regular 2011 bumper just like the GFX rear lip.
My car is Obsidian just like yours Jeff Ive been waiting to pull the trigger on these and am now hopeful that they'll actually fit. Im not too keen on cutting holes into the bumper...it would be unreal if one of you guys could do a diy when you receive and install your lips
Holy ****e.
I'm really confused now.
Let me see if i have this straight:
For a 2011 IS - Your options are ordering the 2011 F Sport complete front bumper assembly for $1500 from Sewell.
-Or- Purchasing the side inserts shown on sewell's website? But we aren't for sure if these inserts will fit on the stock 2011 bumper as of yet?
Am I correct?
Am I correct?
Keeping it Real
98% sure they'll fit, but you'll need to drill holes or find another way to mount it.
The bumpers are likely shaped the same (they usually are). As for the "it doesn't make sense that they'd make two" comment, Toyota/Lexus makes multiple options for things all the time. For less consequential stuff than this, it's definitely possible, and it does happen. More so for Lexus even than Toyota.
Jeff
Jeff
IS Front Lip
It seems that most think the F-Sport Front Lip will fit a standard IS; but has anyone actually installed the lip on an IS? I would love to see pictures or see the instructions on how this lip is installed. I really want to add this to my 2011 IS250. Thanks for any additional information.
I too am curious to see if these will fit on a stock 2011 bumper and the process involved to do so.
