Does my fuel gauge have problems?
A few weeks back, I had like 9 miles remaining as the range. I refilled partially since I was broke and the the range nor did the fuel gauge needle move at all. I thought there was a leak maybe but I made it home with 1 mile remaining. My friend suggested that I reset the computer so I disconnected the battery for 30 seconds and that worked. Less than a month later today, this happened again. Any suggestions as to what is wrong with it?
You probably didn't add enough to affect the sender in the tank. I've never seen that with my IS, but I did have a loaner RX that I was trying to be "frugal" with when I returned it and adding $5 didn't move the gauge or range. So I put more in... just to find out that all the sudden the needle and range jumped... so I ended up putting more in than I wanted to.
If you're only adding a little fuel at a time, it's probably wise to note how many gallons you dropped in, then estimate your range and use your trip meter or odo to make sure you don't run out of gas. Be conservative and use 16 or 17 miles per gallon around town and you should be fine.
This happens to me all the time. It doesn't matter if I fill it up halfway, or all the way, the needle would take at least 5 to 15 minutes to actually move. I went to the dealership and they said that nothing was wrong, but it keeps doing it at every fill up. It's quite annoying.
It shouldn't do that if you shut the vehicle off first, refuel, then restart.
IanShere
GX - 1st Gen (2004-2009)
09-24-14 08:19 AM
