My coilover experience resulted in fail!!!
Each key is different. And there is absolutely NO clearance, only enough to put a paper that is folded a couple of times. I didn't think so either till I saw it myself.
Seriously the dealer has the master key. Don't risk damage to the wheels, just adjust the coil height.
If you are in a desperate bind, do what other posted. Use the wheel thieves' method...
hammer in a small socket and unbolt the damn thing. That's what wheel shops do when you lose the key to your wheel lock. That's how thieves end up getting away with your wheels when you have wheel locks on.
Then bring it to the dealer and ask them for warranty on the damn thing because it broke and you were forced to replace your flat tire.
Car is beautiful, and the broken lug lock situation sucks, but I still can't get over how much room you have in your garage! I would kill to have that much space!!!!!!
If your not comfortable using the hammer method with the smaller socket, the dealer CAN get it off for you. They almost always have a master key to remove them. Just tell them you need it off now and that you'll order a new key after. There's no point in welding the old key, might as well get a new one, if its already broke off it will eventually break again.
I don't know if the Fsport keys are the same but I just had to pick up a wheel lock key for my IS350 from the dealer today and it was under $20 after tax. Just bring your broken one to the parts counter and they can match the pattern.
I don't know if it's too late for this weekend because not sure if dealer service is open on Sundays...maybe try calling the Lexus roadside and see if they can help??
