Anyone actually SOLVE the dash rattle? Dealer's performed TSIB twice...
Creak/pop/tick sound from radio area/dash requires new cushions on both sides of each screw hole of the radio board that join the circuit board to the back panel ( plastic cover )
they are washer type cushion rings... there is a total of 18 needed for the 9 holes, 9 of them are to be placed on front of the circuit board ( LCD facing upward )and the other 9 on the back of circuit board ( LCD facing downward)
you start off by removing the integration panel assembly ( radio lcd integration panel )
** make sure that you discharge all static electricity BEFORE YOU HANDLE the printed circuit board *** meaning= touch metal surface with bare hands. and also make sure you WASH your hands before starting this job ***
remove the 4 screws that hold the circuit board to the integration panel
when screws are removed carefully detach the cable connector for the board and remove back cover panel to access circuit board.
then you will paste in 9 cushions, one at each spot of the front circuit board (LCD facing upward) and the other 9 - one at each spot (LCD facing downward)
tighten up screws.
Voila.
tighten up screws.
Voila.
