Condensation in Fog Light Housing
Old 03-28-11, 02:46 PM
new.era.13
new.era.13's Avatar
Default Condensation in Fog Light Housing
So it has rained heavily in the bay area this past week. And i started to see condensation in both of the fog light housing. But after removing it, i discovered the passenger side has a crack near the bolt. While i couldn't find anything wrong with the driver side housing.
What do you think I should do, the crack looks quite big. I am already out of warranty.
Old 03-28-11, 02:49 PM
Bigrahizzl
Bigrahizzl's Avatar
damn, got to keep that warranty up to date
Old 03-28-11, 02:51 PM
NickTomsyc
NickTomsyc's Avatar
Mine has a ton of water in it too, was like that when I bought it and get $750 off the price, but that wasn't enough. From lexus a housing with AFS/HID is like $1100. I would say dry it out really well, silicon and gorilla glue on it and give it a go.
Mine had enough water that it pooled and shorted the ballast - have all the parts to fix just am waiting until its nicer here to try and fix on my own.
Ebay has a bunch for ~$400 which may be an option
Old 03-28-11, 02:54 PM
new.era.13
new.era.13's Avatar
Well its the fog light housing, they housing is only 150 for each side. but i don't want to buy new ones.
Old 03-28-11, 03:04 PM
NickTomsyc
NickTomsyc's Avatar
shoot my bad... mine is a big guy.
I would still try a hair dryer, some silicone and something to try and reseal it.... if it doesn't work you're out $10 and a hour
Old 03-28-11, 03:05 PM
edgeucated
edgeucated's Avatar
my driverside fog light house was cracked before too. I just bought a new one on ebay
Old 03-28-11, 03:08 PM
ISF4life
ISF4life's Avatar
take it out , clean it dried, silicon the crack... seal it... put it back
new.era.13
new.era.13's Avatar
i glued it for now, but i dont know if it will work, and i still cant find reason why there is water in my driver side.
Old 03-28-11, 03:13 PM
shiny250
shiny250's Avatar
just dry out the housings and seal the crack. as for the drivers side, you can try putting the housing under water and check for bubbles. if there's bubbles then theres a crack or broken seal where the bubbles are coming out from. then dry out the housing and seal up the crack. if there arent any bubbles, then the place where the bulb goes into the housing might have been improperly installed. check that too. goodluck finding it!
Old 03-28-11, 03:16 PM
KillaIS250
KillaIS250's Avatar
^ Do what shiny says, if you see a spot where the water is getting in, seal it with some Hondabond or something else depending on where it is. Hondabond works really well
Old 03-28-11, 04:45 PM
rizzy
rizzy's Avatar
http://cgi.ebay.com/ebaymotors/Lexus...Q5fAccessories
$65 for the housing.
John00
GX - 2nd Gen (2010-2023)
05-21-21 02:17 PM
chingwodap
05-28-14 10:36 AM
TXLX
06-24-07 06:39 PM
jsten23
03-25-07 04:46 PM
Goldglv
03-22-07 08:51 PM
Quick Reply: Condensation in Fog Light Housing
