Gas mileage?? not clear
If 12 miles takes you 45 minutes, obviously you're stopped a lot and accelerating/decelerating a lot, so I can definitely believe you'd get gas mileage on the low end of the IS350 range (I also have a 2007 IS350). However, 12 MPG sounds very low, especially if you don't drive it hard and use 93 octane. I couldn't begin to speculate on what might be causing it, but it definitely seems anomalously low.
And slidingIS: If you're considering a 2IS, I wouldn't focus on gas mileage as a major criteria in deciding between the options (250, 350, AWD) because they're all very similar to each other and the factor that influences gas mileage most is personal driving style. I guarantee there are people that get worse gas mileage in their 250's than other people get in their 350's. My commute is 40 miles a day, 80% highway, and I get 26 mpg+, and on pure highway driving I've seen 33 mpg. So in my opinion, if you want a 2IS, determine if you want 300 hp or 200 hp (and if the extra 100 hp is worth a few extra thousand dollars) and whether you want RWD or AWD, then make your choice.
Has a pole been created for this already? If not, might be helpful to see Year | Model | ECT Button set to? | Gas mileage.
I have an 08 250RWD that can push to 350mi per tank.
There are SOOOOOO many factors that affect fuel efficiency that the #s get quite skewed after a while. But I personally saw on my first road trip in my '06 IS350 w/ 30k miles that I netted 24.9mpg hwy.
Factors that affect mpgs :
*Engine wear and up-keep
*Tire wear and up-keep
*Right foot
*Top tier fuel or non-E85 content fuel
*Alignment
and so-on...
*Right foot
*Alignment
and so-on...
*Right foot
*Alignment
and so-on...
*Right foot
*Alignment
and so-on...
Damn i'm really happy i got an IS250
My last road trip i got about 33mpg driving between 65-75mph the whole time, more towards the 75 then the 65 tho.
I use the Road Trip app on my iPhone to keep track of MPG, so far im getting 29.68 MPG average! The lowest i've ever gotten was 25.07mpg on a tank, that was when i got stuck on the freeway due to road closure and was moving so slow the car was pretty much idling for over an hour.
