Warning light / Check VSC?
I am working on a buddy's wife's car. He is not helping because he is in Afghanistan. Anyway...
I am getting the warning symbol in the center of the dash with the text "check VSC." I am also getting the P/S light in the bottom right corner. The car will not start. Do you have any suggestions? The nearest dealer is 90 miles away.
Not to be a Debby-Downer, but that happened to my car last week. It turned out the timing chain hadn't been torqued to spec after the valve spring recall, and by engine shaved itself to death.
I hope that's not the case for you.
Hopefully she does not have a trashed engine.
And if she does have a trashed engine (as in Aaron's case), it would only be due to dealer negligence (not tightening the timing chain correctly during the recall) and it would be replaced free of charge, so I wouldn't worry much about that.
Happened to me too. They said that the seal around the gas cap was defective and let air in the gas tank. The dealer replaced the gas cap and reset it. Is it still under warranty?
cel,vsc and triangle lights came on my vehicle after the battery died. jumped car and still on. so what i did was disconnect the battery for 15 minutes and reconnect it and SHAWOW. gone.
hope this works for you too.
if not run up to autozone and have them scan it for you. its free.
NINAPOO24
ES - 5th Gen (2007-2012)
04-02-17 04:16 PM
