DIY-Cup holder Led
Old 05-29-12, 03:12 PM
  #61
Initial G
Initial G's Avatar
Originally Posted by ydnandy
Sorry to be off topic, but what carbon fiber kit is that? Looks good!
I don't believe its a cf kit, I think the OP just wrapped it in cf. With the bottle of water in the cup holder, you can see that some of the cf has peeled off from the cover of the cup holder and it looks like a red wood grain panel.
Old 05-29-12, 04:44 PM
  #62
ydnandy
ydnandy's Avatar
I figured it was an overlay/wrap, just curious which one. It seems to fit really well around the shifter and other edges. I want to do this, just don't think i have the patience to make it look good
Old 05-29-12, 04:55 PM
  #63
Kitty2IS
Kitty2IS's Avatar
this looks so good compare to stock led !
Old 12-22-12, 07:33 PM
  #64
Toxicxk23
Toxicxk23's Avatar
The rectangular LED thingy for the armrest cup holder LED, can THAT be replaced instead of having to wire in a new LED? I wanna replace that one and the one near the map light to blue.
Old 12-24-12, 01:05 AM
  #65
ImportISF
ImportISF's Avatar
Originally Posted by Kdash106
cr3ativ3x- how easy is it to change the dash light and cluster light? just a simple plug and play or solder?
I second this
Old 12-24-12, 01:37 AM
  #66
Kentchup
Kentchup's Avatar
pretty cool mod, might attempt it later down the line
Old 11-30-14, 05:28 PM
  #67
jtsimaras
jtsimaras's Avatar
I did this today as was too cold out and I was bored.
Wired to shift indicator light instead so I can easily remove console pieces in future.
During the process I broke one of the garnish trims so i glued and carbon vinyl wrapped to hide the crack.
Old 11-30-14, 06:50 PM
  #68
dorkacho
dorkacho's Avatar
Originally Posted by cr3ativ3x
I did this awhile go too... You can change every single light inside your car or even add it. From my perspective, the green is so ugly...
where in socal can get this done? looks so much better than stock!
Old 12-01-14, 11:53 AM
  #69
Ants350
Ants350's Avatar
Originally Posted by jtsimaras
I did this today as was too cold out and I was bored. Wired to shift indicator light instead so I can easily remove console pieces in future. During the process I broke one of the garnish trims so i glued and carbon vinyl wrapped to hide the crack.
looks nice! Check your tires there low lol..
Old 12-01-14, 07:05 PM
  #70
jtsimaras
jtsimaras's Avatar
Thanks ...Tires are a ok..
Old 12-12-14, 01:15 PM
  #71
eclipsegst
eclipsegst's Avatar
were did u buy the led?
Old 12-12-14, 04:40 PM
  #72
jtsimaras
jtsimaras's Avatar
ebay:
http://www.ebay.ca/itm/351176990263?...84.m1439.l2649
http://www.ebay.ca/itm/251689643899?...84.m1439.l2649
Old 12-13-14, 01:18 PM
  #73
eclipsegst
eclipsegst's Avatar
why does it look like a 90 degree bend? did u just bend the wires or did it come like that?.
Old 12-14-14, 09:02 PM
  #74
jtsimaras
jtsimaras's Avatar
I bent them ..wires are fine I've built numerous circuit boards etc and not worried about solder breaking off.
brociouz
12-18-21 02:14 PM
metrathon
12-03-16 11:34 AM
Quick Reply: DIY-Cup holder Led
