Putting oversized tires on FSport wheels...
Old 04-11-11, 08:27 PM
RTIS250
Yes. I drove the LFA.
RTIS250's Avatar
Default Putting oversized tires on FSport wheels...
So Lexus recommends 225/35 and 255/35 tires on the 19" FSport wheels, which are 19x8 and 19x9. I need new tires, and have been considering bumping the tire size up to 235/35 and 265/35, to get a but more width and height to help fill out the wheel wells. Im looking at a used set of Nitto Invo tires someone has, which are 235/35 and 285/30... and im looking for opinions on whether of not this will work. I know the fronts will be fine, but the rears i think will be too wide for 19x9 wheels. I beleive Nitto calls for a minimum 19x9.5 for that width. I currently have badly cracked Goodyear F1's, so i need to make a choice soon. Thanks in advance for the opinions...
Old 04-12-11, 12:24 AM
RTIS250
RTIS250's Avatar
No opinions?
Old 04-12-11, 02:35 AM
DAZ1
DAZ1's Avatar
Going up one size, front and rear would be best. The 285/30/19 is way too big for the wheel and the car.
Old 04-12-11, 05:24 AM
mikes rx
I use "..." ....... a lot
mikes rx's Avatar
I've got 265/35/19 on my rears. Did it for the same reasons as you. Haven't had any problems.
Don't know if that helps you or not
Old 04-12-11, 08:11 AM
DexRox512
Turkey Killer
DexRox512's Avatar
I had 275's on my rears...worked and looked great.
Old 04-12-11, 09:08 AM
Sffd103
Fire Slayer
Sffd103's Avatar
I think 285's are too wide for a 9" wheel.
Old 04-12-11, 09:16 AM
kyoso23
kyoso23's Avatar
I'd say a 275/30 would be pretty much maxed out on a 9" wheel. I'm going to attempt this next time around, but I'm pretty sure I'll need to roll the rear fenders a tad to clear the tire as I'm running a 10mm spacer on the Fsport wheels. I am thinking a 235 on the front would be perfect, the 225 feels a tad to "stretched" on the wheel under agressive cornering.
Old 04-12-11, 10:25 AM
Eldr1dgE
Eldr1dgE's Avatar
235/35 up front will work and 285/30 in the rear could work depending on the sidewalls of those nittos..there's a member with an is-f that did it on the stock is-f wheels which is the same width, but with contis..
https://www.clublexus.com/forums/is-...xtreme-dw.html
The thing is all manufacturers are different even if they're the same size..
Old 04-12-11, 11:31 AM
Gville350
Gville350's Avatar
I had to debate whether or not to go oversized with my 18s...but alas, to have to not worry about rubbing I got stock sized tires. Good to know that a slight bump up to 235 and 265 won't hurt anything for future reference.
BTW, 285s would fit on a 19x9...but would it work well on the vehicle? Doubtful. Reminds me how one of my friends mounted 225 BFG drag radials for his Honda on OEM 14x5.5 wheels. Looked and worked like crap. LOL!
Old 04-12-11, 12:44 PM
quang
quang's Avatar
I remember saw thread saying that putting 235 in the front would rub on F-sport
Old 04-12-11, 01:07 PM
iRock
iRock's Avatar
I got 235 on the front on my f sport rims no rubbing but I'm not lowered yet either
Old 04-16-11, 01:49 AM
flexthatdx
flexthatdx's Avatar
I got 235's on the fsport, car is lowered, no rubbing
Old 04-16-11, 10:41 AM
sktn77a
sktn77a's Avatar
235 is borderline on an IS. Some tires will work, some rub - appears to depend on the shoulder profile of the tire. If you search this forum you'll see some posts where the 235s work and some where they rub. This is probably why Lexus don't go higher than 225 on the front of any of the IS cars!
Old 04-16-11, 10:43 AM
flektone
flektone's Avatar
are you dropped on coils? if not its going to look wack
iceache925
06-05-21 08:06 AM
Vibes63
08-15-13 06:50 PM
SCWB
03-03-13 10:45 PM
jkutch
07-15-11 12:46 PM
MotoX
12-27-09 03:30 PM
Quick Reply: Putting oversized tires on FSport wheels...
