Spacers for 2011 is350 AWD
Can anyone help give me a quick rundown on spacers for stock awd? I unfortunately have both a terribly high stance and the rears are ridiculously high and pushed in. I'll deal with the height later down the road with possibly some megan ez coilovers later.
For now, just want to push those rears out a bit. Anything I should keep in mind? Any recommendations on brand, type, size?
I have the same wheels (with 245's instead of 225's in the rear). I put 20mm spacers on the rear and it's very flush, but I don't want to push my front's out that far, so I am thinking of putting 5mm on the front and reducing the rear to 15mm.
I know quite a few people have run the 20mm/10mm setup with success. I do like the 20mm on the rear, but I think I'd like the 15mm more.
Jeff
Jeff
Jeff
Jeff
^that looks great!
I actually want to buy a set of wheels that will push the front out 15mm and the back out 25mm, will it look flush or too much?
btw the OEM AWD wheels have +45 offset right?
Stock wheel sizes on the 2IS (ISx50 & IS F, USA & Canada)
16x7.0 +45mm (Front & Rear, 06-10 Canada IS250 Standard Wheel)
17x8.0 +45mm (Front & Rear, IS250/350 AWD Only Choice, IS250 (USA All years & Canada 11+)/350 Standard Wheel, Canada 06-10 IS250 Optional Wheel)
18x8.0 +45mm (Front, IS250/350 RWD Optional)
18x8.5 +50mm (Rear, IS250/350 RWD Optional)
19x8.0 +45mm (Front, IS F Standard Wheel)
19x9.0 +55mm (Rear, IS F Standard Wheel)
So if you have 17's, they are 17x8.0 all around.
Jeff
Jeff
