Hub Centric Ring (LC818)
Old 04-13-11 | 05:25 PM
Bigrahizzl's Avatar
Bigrahizzl
Default Hub Centric Ring (LC818)
Was wondering if i need them. I picked up the rims from a member but i dont know if i need them for these rims or not. I just found out what these are and what the uses are
Old 04-13-11 | 05:48 PM
mvlbr's Avatar
mvlbr
Ideally yes but if your not getting any vibrations while driving you're fine.
Old 04-13-11 | 05:54 PM
JoeCombs's Avatar
JoeCombs
ha i had the same question, except its with my spacers, i installed them myself and when i was done i reached in my pockets and realized i left 1 ring in my pocket... so one side has it and the other does not.
still the same answer though? no vibrations and im good?
Old 04-13-11 | 05:55 PM
mvlbr's Avatar
mvlbr
No vibration you're good.
Old 04-13-11 | 06:51 PM
Bigrahizzl's Avatar
Bigrahizzl
yes i do have vibrations and i was mistaking it with either my new suspension or my wheels being bent or not balanced properly. Now i know that it could be this. So what size is correct and where can i purchase them??
Old 04-13-11 | 06:59 PM
Silver10's Avatar
Silver10
I believe our hub bore is 66.1
Old 04-13-11 | 07:09 PM
MashinA's Avatar
MashinA
b2autodesign is a vendor on here i know he sells plastic hubrings $35 for a set of 4
i have two on my front wheels and i think it helped with the vibrations a little bit.
Old 04-13-11 | 07:11 PM
Bigrahizzl's Avatar
Bigrahizzl
^^^^ nice, are they easy to install???
MashinA's Avatar
MashinA
yea you just put them on the wheel. matter of fact this is what im talking about
http://cgi.ebay.com/ebaymotors/4-HUB...Q5fAccessories
$6 for 4
Old 04-13-11 | 07:55 PM
SB350's Avatar
SB350
Isn't our hub bore 60.1 mm?
Old 04-13-11 | 07:59 PM
Trza's Avatar
Trza
Its 60.1, I just installed some on my rims. You need to find out what the outside diameter of the LCs are though
Old 04-13-11 | 08:27 PM
Bigrahizzl's Avatar
Bigrahizzl
cool, thanks MashinA. Does anyone know the diameter for LC818?
Old 04-13-11 | 10:55 PM
dappy's Avatar
dappy
According to Wheeldude.com, if your LC818 are 5x114.3 bolt pattern and it's vibrating, the PCD may be 72.6 and not 60.1. You'll just need to get some 72.6-60.1 hubcentric rings like these on eBay.
Old 04-13-11 | 11:03 PM
Bigrahizzl's Avatar
Bigrahizzl
^^^^^ thanks dappy!
Old 04-14-11 | 05:29 AM
simple's Avatar
simple
Hub rings are a must, I'd broke 2 stud on the rear driver side due to running ichiba 5mm spacers, Idk why ichiba didn't include 5mm hub rings as well. ... Now I'm running no spacers and no center caps in the rear
