New owner questions.....
Old 04-15-11, 11:53 AM
Kurtz
Kurtz's Avatar
Originally Posted by calvin2376
Well weird. So if the switch is in either "L" or "R", both your mirrors tilt down, but if it's in neutral, neither do. Is that correct?
Yup that's exactly how mine works.
Old 04-23-11, 01:08 PM
Pat8635
Pat8635's Avatar
Default 2010 hs250h does the same!
[QUOTE=anthrax144;6311535]
1. This has nothing to do with your key fob. The side mirror that will tilt down when you put it in reverse is the one you have selected on the rocker switch on the driver's door switch panel. So if the rocker switch has L selected and you put it in reverse, the L mirror will tilt down but the R mirror will not and vice versa.
Not sure that's correct. IIRC the mirrors lower (both) when you have the mirror switched to either left or right but not when it is in the middle (neither mirror selected.) I haven't seen just one mirror or the other lower. Mine's an '06 so maybe it's changed on newer models.
I have the same functionality on my HS....
DJNile
03-14-18 06:55 PM
RLM
RX - 4th Gen (2016-2022)
06-23-16 12:49 PM
Trogdor796
04-10-16 12:15 AM
2Fast0
05-04-06 07:10 PM
LexRexBlue
11-11-05 10:30 AM
Quick Reply: New owner questions.....
