Pics of my '06 IS250 with 2011MY headlights w/ LED Strip
#196
sooo just spent few hours on the headlights and just like another member here the led strips don't work
My guess is that thinktwice had stock HID's and relocating one cable would work for him. And since originaly my car didn't come with HID's i think i need to relocate the wire in a differen slot....but which one![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
I have non HID so I'll be going down this road like you some day when I get these lights. Keep us posted when you can.
#198
So i got my LED strip to work. Turns out that i had to connect the red wire with the white&black strips wire. I left LEDS on 100% but i think they're to bright...oh well. I'll wait till someone comes with some solution.
I even tried to connect the red wire to the Ignition fuse thinking that it might work...fail
#203
Received 1,063 Likes
![Lightbulb](https://www.clublexus.com/forums/images/icons/icon3.gif)
Finally, adding some much needed "Light" to this thread....... !!!
Some things to know... If you buy a pre-made kit, you don't have to deal with any of this stuff...
The only thing you have to do is swap the Flasher Relay cube, which sits in the space above the Brake & Gas pedal under the dash.
If you have an IS with AFS, you will indeed get a flashing AFS indicator light.. If you have an IS with just the Halogen headlights, you will not have a flashing AFS indicator.
So far the only known way to stop the blinking AFS light, is to crack open the cluster and block the light that passes through that area with something Black.
Also, the bumper brackets that screw into the bottom of the headlights, will need slight modifications to be attached to the new MY2011 lights.. Basically dremeling some of it off that sits over the LED wire dome cap on the underside of the housings.
But still, only 2 screws will line up after that.
I tried the new step mentioned, of only swapping the GREEN wire location, that DID NOT work on my 2008 IS-F.
So I went with what "thinktwice" originally did..
I snipped the thinner solid red wire, then tapped it into the Black & White wire underneath it..
Then I changed the pin location of the Green Wire to the empty spot... Done.!!
I also tested the Solid Black wire and Solid Green wire to confirm the differences between the 50% & 100% brightness of the LED strip.
I went with 100% power.
Also, the new Flasher relay needed is indeed Lexus / Toyota Part # 81980-06020
That takes all of about 5 minutes to find unplug & replug the new unit.
I only got pics of the Flasher swap so far.. (I was in a rush)
I will try to update this post in the near future with how the wiring looks before and after the slight modification done to the primary male plug connector on the new headlight.
Thanks for all input in this thread..!!
Regards,
~ Joe Z![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
Picture 1 = NEW Relay
Picture 2 = NEW Relay and Old Relay, side-by-side
Picture 3 = Old Relay & Location (mine was green & blue)
Picture 4 = New Relay & Location (brown & black)
Picture 5 = Pearl Yellow LFA #P014 & MY IS-F
Regards,
~ Joe Z
#204
Main harness pictures "coming soon"
Picture 6 = Pearl Yellow LFA #P014 & MY 2008 IS-F
Picture 7 = Sunset with LED's ON
Picture 8 = Everything OFF
Picture 9 = coming soon
Picture 10 = coming soon
~ Joe Z
#208
I've had my Sewell kit for five months and there is a little bubbling, although someone would only notice it if I pointed it out.
