Pics of my '06 IS250 with 2011MY headlights w/ LED Strip
#541
yeah, the second pic, that the LED 3 wires harness there, so you just cut the green wire on both lights and run them together to the ING2 fuse box which is locate in the engine bay, but make sure you buy the add on fuse line for that, I made the thread while back, let me check
#542
here the link look at the second pics, that the add a fuse line and two ATM 10A fuse you have to buy and the fuse line, and third pics is the fuse line add to IGN2 in the fuse box
https://www.clublexus.com/forums/is-...t-on-leds.html
#543
thanks for the link. is there a place where i can just go out and buy that same relay? im trying to do the install either today or tomorrow for an event coming up. if not, i think i might have to do what JOEZ did.
this sucks.
this sucks.
#545
Received 1,064 Likes
![Lightbulb](https://www.clublexus.com/forums/images/icons/icon3.gif)
^^ i meant the little 3 prong harness. i think you were talking about the the cover cap, which i think i just reuse from the ones on my car. im just trying to get ready for hte install tomorrow.
this sucks.
this sucks.
Problem 1 - use a tiny mini screwdriver and release the tab from inside part of the harness... Then the green wire will pull out easily from the back side....
Problem 2 - Blinker relay ?? If yes, you need to buy the proper oem part# mentioned in this thread...
Problem 3 - Yes you need that dome shaped cover with integrated wire and connector in order for the LED's to function.. And to seal that area..
You do not have this cover on your current lamps. And yes, you can only use the proper oem cap for that..
![Name: 20120915_132038.jpg
Size: 428.8 KB](https://www.clublexus.com/forums/attachments/is-2nd-gen-2006-2013/429970d1501346840-pics-of-my-06-is250-with-2011my-headlights-w-led-strip-20120915_132038.jpg)
~ Joe Z
#546
thanks guys. you guys are smart as hell on here.
so this is what im missing correct? seem to come with the dust cover as well.
so i need two of these and that's it,
also, does this look like the part im missing for that harness? looks like it includes the dust cover too. so i need two of these? same part number?
http://is.sewellparts.com/accessorie...2011/5597.html
all of hte other covers and etc will work off my old headlights?
#549
for those of you who had stripped headlights, after ordering that little part for the led harness and cover, looking at the pics below, does it look like i have everything else ready for install? im tryign to do this tomorrow and hopefully i dont run into more problems needing another part. thank guys.
![](http://farm9.staticflickr.com/8049/8135604332_66557e6b64_b.jpg)
![](http://farm9.staticflickr.com/8467/8135575325_cc8702c54f_b.jpg)
![](http://farm9.staticflickr.com/8190/8135574255_d07b23140d_b.jpg)
![](http://farm9.staticflickr.com/8043/8135601082_6da544337b_b.jpg)
#550
![](http://i902.photobucket.com/albums/ac223/ohiois350/2e2e922f.jpg)
![](http://i902.photobucket.com/albums/ac223/ohiois350/Untitled-1.jpg)
i looked under the lexus IS-F fuse box for IGN2 and it seems we use the 20a fuse. and this is what i bought,
![](http://farm9.staticflickr.com/8049/8145268948_933a95a2cc_b.jpg)
it holds 2 10a fuses. and it says MINI. will this be ok ? i dont want to run into any problems.
please help, my car is currently torn apart. thanks guys.
#554
yeah, basically everytime the car turns on, it will be on. not sure how the led will work in the long run but for now, that seems to be the way i want to do it.
#555
dammit, my rear cover for the high beam doesn't even fit the newer 2012. this is trustrating, now i have to leave my car like that until the part arrives.
this is my light rear cover
![](http://farm9.staticflickr.com/8330/8145830832_3b6932ea4b_b.jpg)
this is the 2012 rear cover, not even the same shape.
![](http://farm9.staticflickr.com/8326/8145798249_44510853b2_b.jpg)
