Pics of my '06 IS250 with 2011MY headlights w/ LED Strip
Old 05-15-11, 11:45 PM
  #106
aLexGS350
aLexGS350's Avatar
Very nice mod! I hope they come out for the GS!
Old 05-16-11, 06:02 AM
  #107
Thinktwice
Thinktwice's Avatar
Originally Posted by ohiois350
thanks, I have an idea but I don't know it would work or not, so wire the green wire to acc fuse box and tap the black wire to the low beam, so every time you turn on the car the led come on without turn your parking on? and after you turn on the lowbeam so the leds get dimmer?
I'm not sure though that the dimmer LED would override the brighter LED with that setup. Why wouldn't the brighter LED stay on regardless? You almost need some sort of way to have them switch.
Old 05-16-11, 08:07 AM
  #108
ohiois350
ohiois350's Avatar
[QUOTE=Thinktwice;6392930]I'm not sure though that the dimmer LED would override the brighter LED with that setup. Why wouldn't the brighter LED stay on regardless? You almost need some sort of way to have them switch.[/QU
because just my though try to be as function as 2011, but if the 100% bright is not over kill the low beam, that would be nice? since I like brighter, but i don't at night are people see is just the LEDs
Old 05-16-11, 08:37 AM
  #109
Thinktwice
Thinktwice's Avatar
Well I will say the 100% brightness LEDs are pretty bright at night. Not bright enough to light up the road of course, but bright enough to probably annoy some drivers directly in front of you. I liked the look of the 50% brightness LEDs at night with the low beams on more. But nothing beats the 100% brightness of the LEDs during the day, so it's worth it IMO.
Old 05-16-11, 08:47 AM
  #110
ohiois350
ohiois350's Avatar
I thinking relay fuse to split the power and test on some source of the light to see there are a solution? I like the bright of the LEDs, but at night if it too bright is kinda annoying
Old 05-16-11, 08:49 AM
  #111
fr0st
fr0st's Avatar
thinktwice has definitely given great progress so far, but i also agree with you. there has to be a way to dim during night.
Old 05-17-11, 04:44 AM
  #112
davidky808
davidky808's Avatar
looking good! I like the new look of the headlights and was wondering, if you had your factory halogen headlights before, how did you install the d4s hids? As far as power and the wiring is concerned. Are you just running your low beams in the projector with the high beams in the actual slot provided? I'm not familiar with how d4s hids work.
Old 05-17-11, 06:35 AM
  #113
Thinktwice
Thinktwice's Avatar
D4S is just an HID bulb type. The new 2011 HID headlights only accept the D4S bulb for the low beam, so it was just a matter of placing the bulb where its supposed to go in the headlight. The only thing connecting the headlight to the rest of the car is the harness connector (plug), so all of the wiring in the headlight connecting the lows, highs, LED strip, parking light, turn signals is run through that.
Old 05-17-11, 02:55 PM
  #114
davidky808
davidky808's Avatar
Thanks for the clarification. I also wanted to know what this plug is for in the pic below?
Attached Thumbnails Pics of my '06 IS250 with 2011MY headlights w/ LED Strip-headlight-2-copy.jpg
Old 05-17-11, 03:25 PM
  #115
ohiois350
ohiois350's Avatar
that plug look like 9005 female plug for high beam? I might be wrong, but from the head light look like it from 2010-2011? because from 06-09 headlights has box dust cover, not round cover like that
Old 05-17-11, 10:55 PM
  #116
davidky808
davidky808's Avatar
^oh ok that makes sense. what about this plug? Sorry I'm not familiar with lexus headlights at all.
Attached Thumbnails Pics of my '06 IS250 with 2011MY headlights w/ LED Strip-headlight-3.jpg
Old 05-18-11, 05:42 AM
  #117
Thinktwice
Thinktwice's Avatar
That is the connector for the turn signal and LED. I don't know if you have it already, but there is a round cap that covers the bottom that has the wire coming out of it to connect to that plug.
Old 05-18-11, 07:31 AM
  #118
davidky808
davidky808's Avatar
^You mentioned that you needed to buy covers? Which covers were those? And Part #?
Old 05-18-11, 08:32 AM
  #119
ohiois350
ohiois350's Avatar
is that plug attach to the headlight? or on the body frame? is it the HID headlight or halogen light?
Old 05-18-11, 08:39 AM
  #120
Thinktwice
Thinktwice's Avatar
That plug is apart of the whole wiring harness of the headlight. That's a 2011 HID headlight.
Covers/caps to all of the openings where something plugs into. Not sure the part #'s anymore, but if you call or go to a dealership they can print out a photo diagram depicting each part of the headlight assembly with part #'s. Just be sure they're providing you the parts specifically for the 2011 HID headlight since it has some different parts than the others.
Quick Reply: Pics of my '06 IS250 with 2011MY headlights w/ LED Strip
