the oil matenience service soon light comes on?!?! i just changed my oil???
like the title says.... i just recently noticed that when i started my car.... the change oil mateniece light kept blinking... so i changed my oil... and it still does it?? why?
is there a way for me to clear it?
Check your manual:
with car on put the trip/odometer to your odometer.
turn car off
while holding the trip button, turn car ignition ON but not the car on. hold until you see your odometer finish cycling (5 circles i believe that eventually go away and it goes back to your odometer).
Sorry if i messed up a step, but it IS in your manual too!
turn car off
Yep:
To reset the oil change system, follow the procedure below:
1. Turn the engine switch OFF
2. While pressing the trip meter reset ****, set the engine switch to the IG-ON mode. Continue to press and hold the **** until the trip meter displays 000000.
So in other words:
- engine off
- hold down trip meter reset
- tap the start/stop button twice, making sure your foot is off the brake, and continue to hold down the button until the display resets.
On your Nav screen, go to Maintenance then set the miles you want the reminder light to activate for your next oil change. A simple search would produce this info.
So in other words:
- engine off
