How to get side air vent off?
Hi everyone,
I've been looking for instructions on how to remove the left/right air vent off an IS250 but so far I can only find instructions on how to remove the center air vent.
Anyone here knows how to remove the side air vent? Much appreciated.
Thank you.
~Jr.
Thank you.
~Jr.
For the left side, all I did was loosen the bottom dash starting with the two screws and then just popped the panel off on the side. Everything is pretty much pry and pull from there. I'm sure the right side is the same. Just be careful when pulling. I don't even think you have to take out the two screws from the bottom to be honest but, I'm just giving you directions of how I did it.
Go to the bottom of the first page. There is a picture of the dash assembly and what you can expect. The side panel is off and all you have to do is pry and carefully pull out the side vents.
https://www.clublexus.com/forums/is-...ster-lens.html
Blueshark
ES - 5th Gen (2007-2012)
10-21-10 05:23 PM
