i have a 2008 is250 w/ navi question!!!!! disconnecting battery?!?
i have a cd that is stuck and wont eject?
i was reading online some where it said to disconnect the battery and connect it... and it should spit the cd out....
has anyone tried this?
also....will it cause any problems with my navi? do i need to get it reset or something??
PLEASE HELP!!! thank you
i've disconnected the battery a few times - all prior to working on my 2is, and never has it ejected a disc automatically when the battery was reconnected.
since you've already started several other threads asking for (and not getting much) useful advice to remedy your situation, here's mine.
take it to an audio shop that can work with and troubleshoot oem units, or to the dealership.
aside from you tearing apart the center console and trying to cajole the disc out, i don't see how else to get the disc out of your disc changer.
btw, welcome to the 2is section, but try to keep your issues in one thread rather than starting several different ones to address the same issue. hope you understand.
ojuss
02-08-15 10:05 AM
