Oil Change
Oil Change
Hello Everyone,
I'm trying to change the oil on my IS250 and I just broke a filter wrench trying to remove the filter element cover. Is this reverse threaded? I'm cranking it to the left and no luck at all, any help out there?
Sergio
Sergio
I just changed my oil today too
Now the last time I tried to change the oil on my IS350 I broke 3... yes 3 filter wrenches. These were the $5-$10 ones from Autozone or Discount Auto. They literally just exploded from the pressure of trying to get the filter housing cap off with the cap so much as budging.
The solution... BUY THE SST!
At first I was thinking; "man, $40 for a wrench, definitely not worth it!"
Pfft... Finally after breaking the other wrenches I went to the Toyota Dealership and got the legit wrench. I put it on the filter housing, pushed left a bit and... bam, off it came easy as could be.
My two cents ... of should I say forty bucks.
_
_
Thank you guys....I'll keep on cranking to the left.
Is there a reset for the oil change or do I just keep track. Sorry for the simple questions but I wasn't lucky enough to have an owner's manual.
Sergio
Sergio
You should read the FAQ section at the top of this forum as it has this and loads of answers to simple questions.
https://www.clublexus.com/forums/is-...tart-here.html
Here's the quick link to your question:
https://www.clublexus.com/forums/is-...ml#post1723025
Super Moderator
The genuine Toyota tool is part number 09228-06500-02, but quite honestly, the Assenmacher Specialty Tools TOY640 is every bit as good for a fraction of the price. http://www.amazon.com/Assenmacher-AS...3446251&sr=1-2
If you're breaking your plastic Walmart style filter wrench, then the casing is probably a bit tight. So I would recommend buying the metal special tool that everyone suggested. It grips better because of the smaller diameter, and is obviously much stronger. Get the TOY640 though, I have one and it's perfect. Keep in mind that you'll need a 23mm socket in order to attach a wrench to it, if I recall correctly.
Lexus SST: 09228-06501 ~$40
AST SST: TOY640 ~$15
kambam3627
04-13-18 03:09 PM
lilbluu
06-01-10 03:44 AM
