Freshly Added *Fsport lips on non Fsport bumper*
#31
You know wat I noticed Kdash, your bumper doesn't have the headlamp washers. I couldn't take my bumper completely off due to the washer lines, and when I tried to remove them, obviously, washer fluid came out. I had to do all the cutting and install with little room to work with. I cant tell if Jeff had headlight washers as well, but definitely an obstacle to think about for those wanting to do this install.
#38
#39
Don't let the headlamp washer stop you. I too have the headlamp washer and It's real easy to plug the tube. You can use a small plastic bag and a small rubber band. After you remove the tube, cover both ends of the tube openings just like how we wear a condom then belt it with rubber band. There will be some fluid spill for sure, but it will be very little if you can cover the hole fast enough.
#40
To the OP ..... I'm thinking of adding these f sport lips to my non f sport 2011 but was wondering if you feel it can be installed without all the hacking and drilling ?? I'm hoping to see if i can use 3m tape which i have all the confidence of it sticking but wasn't sure about the fitment
TIA
![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
TIA
#42
TIA
TIA
#45
Skirt looks good!!
BTW, on those 19" TSW's, how's the clearance? Stock suspension height?
I just picked up a grey '08 so Im new to the game. Definitely on the hunt for the gunmetal grey Fsport style like these. Love'em!! Anything I should consider with the stock suspension setup?
