Rubbing on 20's
hey guys i need help my driving tire is rubbing but i dunno why im running 20's on my is350.. is anyone else having this problem ??? can some one help me out
i have 245/30/20 falken 452.. and as far as lowering springs i got the megan racing 32 way full adjustable on the is350..lol that was funny about the weight im only 150lbs..
im actually new to the lexus scene, i came from having an evo x to the is350 so theres alot of info i need.. i actually dont know any good websites for after market or anything like that ..
and where are the signs that the tire is getting "cut" - along the sidewall, on the tread, and/or the shoulder blocks?
have your fenders been modified - i.e. rolled, shaved, pulled, etc.?
the more information you provide, the easier it is to diagnose your issue.
the front fenders can be rolled (i should know), but the real issue is your tire size.
245/30-20 in the front on a 20x9 +35 is too wide to not cause clearance issues. and since you have not done any fender modifications to your fenders, that in combination with the wider tires will cause the issue you're having.
two ways of remedying this. either modify your fenders, or switch to narrower tires - 225/30-20 for starters. just remember that while a new set of front tires may cost more than fender rolling, the former is essentially permanent.
if you're not ready to modify the front fenders of your 2is, go with narrower tires w/ the same aspect ratio.
