HID problem
My left headlight comes on only for second and than dies.This is the first time since I have the car.Pop the hood and checked all the fuses,they fine.Don't know where the relays are.Maybe bad ground?Anybody had that problem?
![Bang Head](https://www.clublexus.com/forums/images/smilies/banghead.gif)
Most likely the bulb is going out but it could also be a bad ballast. Swap sides with the bulbs and see if it continues to happen. If just the left side continues to have problems then it's the ballast. If it moves to the right side then you know it's the bulb.
Had the exact problem with my 2008 Avalon Touring driver side. My mechanic switched the bulb from Driver to passenger and passenger side is now flickering. Ordered two Philips D4R from Amazon.com last week at $55 each should arrive this week.
Jack
08 Avalon Touring
Jack
08 Avalon Touring
Your 07 IS250 should use D4S bulb. Also I found the Toyota D4R/DS4 ballast at hidconcept.com at $75 each. Don't know if this will fit the lexus.
http://hidconcept.com/index.php?l=product_detail&p=37
Found this in Youtube on how to change the IS250/350 ballast. Looks like a PITA.
http://www.youtube.com/watch?v=88_gCBHdJoo
