Hey, do you know if it makes any difference which ecu you get? Does it matter if you get ecu from the SC430 vs GS430 vs LS430?
Saw this twins pic on an Aussie forum...sooo nice!!!
well if you can get any these ecu override then you are good to go otherwise maybe should try 2007 gs430 as they are keyless entry but not sure if will work other wise best is aftermarket as you can add turbo and map to best performance
Nice! Physically fitting everything is a big step in the right direction! Have you started digging into the wiring harness yet? I'm curious to get a look at the drive shaft as well
Very nice, great to hear. There's a lot of guys in the states looking at this swap as prices are getting cheaper and cheaper for the 3uzfe....makes buying new rods more economical for boost as well.
