Humming sound at ~40-45mph
Old 06-19-19, 10:57 AM
  #46
Gville350
Gville350's Avatar
Originally Posted by Sin1UZFE
I have this noise that gets louder the faster I go from 45 and up. Replaced one bad wheel bearing. Got new tires. Balanced twice. Replaced front rotors and brakes. Replaced engine and tranny mounts. Had rims checked for bends. Replaced tranny filter and fluid twice. Replaced drive shaft center mount. Had drive shaft checked. Diff fluid changed. All pulleys and tensioners checked. However a similar noise presents itself when revving at idle. I'ma rev at 2500 rpm tomorrow morning and see if it sounds the same. Could be a pulley?
So is your noise issue coming from the engine compartment or the drivetrain? I guess the key is narrowing it down to the general source of the noise and we can work from there. Let us know you find out!
Old 06-19-19, 10:58 AM
  #47
Sin1UZFE
Sin1UZFE's Avatar
Not sure, sounds like the front
Old 06-19-19, 02:17 PM
  #48
Gville350
Gville350's Avatar
"Front", meaning in the engine compartment or the front wheel bearings?
Old 06-19-19, 02:26 PM
  #49
Sin1UZFE
Sin1UZFE's Avatar
Suspected the wheel bearings but they are good. But lately wanna get a 2nd opinion
Old 06-20-19, 02:04 PM
  #50
Gville350
Gville350's Avatar
Does the noise lessen or increase depending on which direction you turn? Read and watch the below for further wheel bearing info :
https://speedfinal.com/which-wheel-b...while-driving/
Old 06-20-19, 02:10 PM
  #51
Sin1UZFE
Sin1UZFE's Avatar
It doesnt, but 2 mechanics have already declared all but the right rear (which was replaced) good.
StayTunedF
01-31-17 12:43 PM
noncom23
02-13-10 09:49 PM
nytoy
01-09-08 07:53 PM
wrw1818
Suspension and Brakes
25
05-02-06 02:34 PM
Quick Reply: Humming sound at ~40-45mph
